Tried to start the e30 today. (electrical troubleshooting)
  • Jordan
    • 12912
    Checked and double checked everything, finished topping off with fluids, connected the battery and gave it a crank.
    It cranked for maybe 2 seconds before the battery died... dammit, forgot to charge it up
    Backed the M3 up to me, and connected jumper cables
    Cranked it again. No start. And again.. no start.. well it cranks like a champ, thats about it.
    After a quick check on the fuse box I noted fuse #10 had blown, I replaced it, and went for another crank. This time I saw it blow
    Before checking what it was I took the fuel line off the fuel rail, bone dry. Had my stepfather try to start it while I listened to the fuel pump... not pumping.
    ARG!! well I looked up what fuse #10 did in the Bentley, and it does say "fuel delivery" amoung many other items. So I suppose fuse #10 is my arch enemy now.
    I have the battery on the charger, gonna leave it on over night. I shall try to track down the problem in the morning, until then does anyone have any ideas?
    https://mtechniqueabs.com/
  • boom-monkey
    • 1104
    Fuse 10 generally blows when the wire for the backup lights shorts out, at least thats what it was doing in my car. I'd see if for some reason or another your wire is frayed and if so replace it (duh)
    • UNHCLL
      • 8790
      Does it pop when you crank, or when you turn the key to the "on" position?
      You have the pump wired up correctly, yes?
      All your chassis grounds are good?
      Below the radar...
      • M-technik-3
        • 18946
        How old is the fuel pump? They are weak units, it could have died while sitting around.
        So grab the multimeter and start ohm out the fuel pump loop.
        • Jordan
          • 12912
          I made a brand new reverse light harness from scratch for my car (much improved over the stock design, thick plastic shielding over the wires etc)
          This is not the problem, that I can say with certainty
          • Jordan
            • 12912
            Pops as soon as the key is turned to the first position forward
            Yes, the pump is wired correctly, the 2 terminals are of different sizes, so it is impossible to mess that up.
            I would assume all chasis grounds are tip-top. All of them were hit with a diegrinder to bring to metal (where paint was sprayed) then bolted down.
            • Jordan
              • 12912
              The pump came out of my parts car, it has been dry and in storage for about a year. It did work fine prior to removal. I will test it tomorrow as I need to fix my multimeter (one of the probes fell off.. ghetto)
              • UNHCLL
                • 8790
                You have a bad ground somewhere if this is the case.
                What is listed for components on Fuse 10?
                Also, just to cover all base's you are running the proper amp fuse?
                Below the radar...
                • Jordan
                  • 12912
                  What makes you think a bad ground, rather then something shorting out?
                  Yes I am running the proper 7.5amp fuse
                  Fuse #10:
                  Seat belt warning system
                  SI Indicator
                  Tach/fuel eco gauge
                  Instrument gauges and indicators
                  Brake warning system
                  Backup lights
                  OBC
                  Fuel delivery
                  Idle Speed
                  Check Control
                  Stop lights/cruise control
                  • UNHCLL
                    • 8790
                    Fuse #10:
                    You have these still plugged in?
                    SI Indicator
                    All connections are tight and correct on back of cluster?
                    Tach/fuel eco gauge
                    Same as Above
                    Again
                    Cluster?
                    [b]Backup lights[b/b]
                    Check tranny switch and connections to rear lights
                    OBC
                    THESE WIRES!!!! - you removed your OBC correct? The wires that should plug into this, all are capped/crimped/sealed etc? I'd be wary of this part....
                    Fuel delivery
                    Check the Pump to make sure its not siezed
                    Idle Speed
                    Shouldnt matter since its not starting
                    Check Control
                    Plugged in?
                    Check the bulbs, connections in tail lights, and cruise control wires under dash on column... You removed CC correct?
                    A bad ground can cause a fuse to pop, for example if a hot wire goes directly to a ground, the fuse will act like a light bulb filament.
                    Keep us posted
                    Below the radar...
                    • randomtask37
                      • 3154
                      98 M3/4/5
                      • AdamF 88iS
                        • 2051
                        You ditched your OBC? Are you sure you bypassed the old OBC relay for the CODE function properly?
                        Adam Fogg- '88 M3
                        Common sense- It's the new 'gifted'
                        • Jordan
                          • 12912
                          Adam, I have no idea what you are talking about, so talk some more about it.
                          Chris, tomorrow I will pull the check control, and the intrument cluster out of the car, then try to start it. This is eliminate alot of variables (about half the damn list) I will also disconnect the backup light harness (even tho i know its good)
                          CC, and the OBC have been removed, I want to say that a hot wire going to ground is very likely (duh) but finding which one....
                          I will inspect that block of wires I asked for pictures of a couple weeks ago, I still dont feel right about that area.
                          And yah, I actually had my stepfather turn the key while i watched the fuse. The wire glows quite nicely (instantly) and then pops maybe 0.5 sec later.
                          • UNHCLL
                            • 8790
                            Chris, tomorrow I will pull the check control, and the intrument cluster out of the car, then try to start it. This is eliminate alot of variables (about half the damn list) I will also disconnect the backup light harness (even tho i know its good).
                            Kill two birds with one stone here... go to the local auto store and buy a big box of 7.5amp fuses.
                            Remove each of the above listed components 1 by 1 and try to start the car after each removal. If you finally start it after removing component X, you know where you're problem lies.
                            As for Adams OBC idea, I do not think this hold water, that is just a memory/ignition cancel inside the OBC. it wouldnt cause the fuse to short/burn up.
                            Given your description of glowing then poping, bad ground/reversed wires are a certainty in my mind.
                            Good luck tomorrow!!
                            Below the radar...
                            • rs4pro3
                              • 5808
                              There are wires on the stock Harness which must be pluged intogether after removal of the OBC to get the car to work. I'd ahve to go look to see where the wires are but they basically the OBC relay box plugs in between the wires. But this shouldn't cuase the fuse to blow.
                              85 325e 2.7 ITB'd stroker
