Tried to start the e30 today. (electrical troubleshooting)
  • AdamF 88iS
    • 2051
    #31
    Originally posted by AdamF 88iS
    The OBC doesnt cut the ignition, it cuts the fuel pump.
    Correction to myself, it cuts both.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Spaz
      Crazy Canuck
      • 2276
      #32
      hey jordan insted of using fuses all the time connect a ligth bulb (sealbeams work well)
      to the circuit, then when its going to blow the bulb with lighten up, and telling you that its shorting, that way you could have the igniton on teh whole time while you trace it and not have to worry about kepp replacing fuses....you learn that trick really quick whne your boss yells at you for going thur so many fuses in a hour :P
      edit: connect the sealed beam to where the fuse would be...i can't remeber which conntecion on the sealed beams you use, i think its the top and the left side prong, let me know if that helps.
      and otherwise i'm going to go through my factory manual and look at some wiring diagrams for you also.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • Jordan
        • 12913
        #33
        I am forever indebted to Adam for the hours he spent with me on AIM tonight narrowing down the field. With his knowledge, and his color coded wiring diagrams we were led to 2 relays, which were plugged into each others connectors. Somehow they got swapped (not all that surprising)
        I must now admit that I do not honestly think I would have ever found this problem without Adam’s help, and for that I am deeply greatful.
        Lets hear it for Adam!
        https://mtechniqueabs.com/
        • Jand3rson
          • 37587
          #34
          HIP-HIP-HOORAY!
          • Brian 89 325i
            • 1450
            #35
            For he's a jolly good fellow
            Brian
            • randomtask37
              • 3154
              #36
              :woowoo:
              good luck starting it.
              ever figure out what the mystery orange connector is for?
              98 M3/4/5
              • derek w
                • 43
                #37
                Sounds like you need an ETM. I have a copy. PDF file, ~20 megs.
                • UNHCLL
                  • 8790
                  #38
                  I told you you needed an ETM
                  Saved my ass many times.
                  Adam stole my glory ;) good job Foggy
                  Below the radar...
                  • Jordan
                    • 12913
                    #39
                    Wanna send that to me?
                      • 37829
                      #40
                      So it runs then?
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • Jordan
                        • 12913
                        #41
                        Originally posted by MR 325
                        So it runs then?
                        No, i have to reassemble the dash before it runs lol
                        • UNHCLL
                          • 8790
                          #42
                          So it runs then?
                          So stop posting here you big sissy.... go start it. :twisted:
                          Below the radar...
                            • 37829
                            #43
                            LOL, exactly :)
                            Keep us updated.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • Jordan
                              • 12913
                              #44
                              Still not getting any fuel, the exterior fuel pump isnt operating.
                              I'm gonna take it out and bench test it
                              • rs4pro3
                                • 5808
                                #45
                                Your pump is probally seized. I had 2 good pumps that came out of running parts cars they sat in the garage in a plastic bin for 8 months then were sold and both had seized up.
                                85 325e 2.7 ITB'd stroker
