My rear end is seeping and gassy
  • Mahalaleel
    • 180
    It looks like there's some minor gasoline seepage coming under the rear bench, under the caps. Both the fuel pump and sending unit sides show signs of seepage. I believe there are two o-rings, one for each side, but I can only find one of them. Part No. 16111744369
    I can't find the fuel sending unit O-ring if there is one. It's raining so I don't want to open them up right now to look at the o-rings.
    Anyone have experience replacing both of them?
  • roguetoaster
    Biggus Tippus
    • 7830
    Should be the same o ring for each side.
    There's also the level sensor gasket that's often missing, 16121150391.
    The thread title makes it seem like you have a personal issue.
    • D.Martijn
      • Sep 2016
      • 1024
      I would also assume both o rings are the same as the one for the drivers side is not listed.
      When you do a search for the driver side sender unit (16141179720), it comes with an o ring. Maybe you could compare the size with the one you pull off of yours.
      Hahaha :giggle:
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • TobyB
        • 5280
        What makes you think he doesn't?
        t
        • Mahalaleel
          • 180
          That too.
          I found another issue that may be more relelvant?
          It looks like a hard line is crusty and it feels damp (fuel)
          How do I shrink this photo?
          • c0rbin9
            • Dec 2015
            • 609
            Paint works for resizing photos.
            1991 318is Brillantrot daily driver (slow restoration)
            • roguetoaster
              Biggus Tippus
              • 7830
              Originally posted by Mahalaleel
              That too.
              With imgur, put an h just before the .jpg and you get 1024x768 or some such smaller resolution.
              Investigate both ends of that hard line to determine if it's at fault or the hose connections.
              • Mahalaleel
                • 180
                Awesome tip for imgur, thank you. I'll check that line out this Saturday, see what i see.
