What work can be done under the dash?
  • WellMax
    • Apr 2017
    • 8
    I am Planning on removing the dash of the E30, I have removed the dash of other cars and I know it is tough, time consuming work. I would really like to remove it only Once for cleaning.
    1.What would you guys suggest that I do while I have the dash removed?
    2.What are some common issue or upgrades that are done under the dash?
    -I plan on removing the dash cluster to fix the odometer/ and gauge's that don't work.
    -I plan on removing the heater/ A-C box so I can Completely remove the rug for cleaning.
    -I guess I can straighten up / clean the area and the wiring under there.
    This info I have searched for and have not found, I would greatly appreciate it.
  • ak-
    • 12422
    I think there are a few foam gaskets that squish between the heater and AC ducting under the dash that deteriorate over time.
    I can't really remember because it's been a long time since I've looked under a dash, but someone will correct me shortly
    You can see what I'm talking about (If I'm right) in this illustration:
    1991 325iS turbo
    • e30davie
      • Apr 2016
      • 1788
      You can remove the dash cluster in about 10mins with the dash still in. Tight squeeze over the steering column, but its do-able.
      Removing the dash and heater assembly I reckon is a big job, you want to make sure you reaaaally want to do that before you start. Every time ive removed a dash from a car ive broken a bunch of clips and stuff and its rattled when i put it back in.....
      • george graves
        • 19995
        Don't remove it for cleaning - if that's all you're interested in.
        If all you want to do is "clean", I'd use an air compressor with a wand.
        Originally posted by Matt-B
