M20 cutting out at highway speeds
  • Balleristic31
    • Aug 2009
    • 4198
    Hey guys. Getting kinda frustrated with this one.
    My brother's car (91 325i manual swapped, all stock ecu, 17lb injectors, 4.10 diff) is having an issue where at highway speeds the car cuts out pretty violently, but at no specific RPM or speed.
    The econometer also seems to lose signal when the car cuts out, but the tach stays consistent. Is it possible we are still losing timing data?
    Parts we have thrown at it:
    New CPS
    Swapped ECU
    Swapped AFMs
    Swapped Coils
    New fuel pump
    New fuel filter
    New fuel pressure regulator
    New Ignition Wires
    Swapped plugs
    New injector harness
    New coolant temp sensor (ecu)
    Swapped distributor caps
    New TPS
    Vacuum leaks all sealed up
    Cleaned/rebuilt injectors
    New valve cover gasket
    Swapped fuel pump and main relays
    Unplugged O2 sensor
    Again it only happens at freeway speeds in higher gears.
    Next step is go probe the fuel pump for power and the ECU during the cutting out. Which pin should I be probing on the ECU to check for power?
    Any suggestions would greatly appreciated!
    -NICK
  • ak-
    • 12422
    Oil pan ground nice and tight as well as others?
    1991 325iS turbo
    • Balleristic31
      • Aug 2009
      • 4198
      Oh thank you for reminding me. We checked all visible grounds on the motor and in the engine bay!
      -NICK
      • Pdxseth
        • May 2012
        • 3124
        My car did that due to an overheating fuel pump, did you put a new or used one in?
        Sent from my iPhone using Tapatalk Pro
        • Balleristic31
          • Aug 2009
          • 4198
          Brand new fuel pump. Oem
          -NICK
          • Balleristic31
            • Aug 2009
            • 4198
            Big update! Did a ton of probing and poking around. As soon as the white connector on the back side of the cluster is disconnected the car runs perfectly! What could this be?
            -NICK
            • 7pilot
              • 475
              1, Gently tighten up the brass screws on the back of the instrument cluster.
              2, Make sure that the voltage regulator brushes are not worn out and causing a partial charging condition.
              3, have the alternator tested to rule out intermittent charging by #2.
              m
              • Balleristic31
                • Aug 2009
                • 4198
                Well we got it! Swapped out the speedo (old one was flakey), cleaned all the contacts and boards on the cluster with contact cleaner and tightened all the ground nuts and all is well!
                Really weird
                -NICK
                • MR E30 325is
                  • Dec 2008
                  • 3299
                  That is super weird. I had a cutout issue years ago and it ended up being the maf element.
                  I threw so much money at it. Was super frustrated that it was as simple as swapping out maf's.
                  Anyways, glad its better!
                  My previous build (currently E30-less)
                  http://www.r3vlimited.com/board/showthread.php?t=170390
                  A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                  • Pdxseth
                    • May 2012
                    • 3124
                    I've heard a lot of people say that an e30 won't run without a cluster, I've never experienced that, I drove my 85 eta around for 6 months with no dash or cluster and it ran fine. Maybe just a late model thing?
                    • Kershaw
                      • 11822
                      I read the OP and I said grounds and I read the fix and I still say grounds. Glad you got it sorted out.
                      AWD > RWD
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        Yeah grounds were my suspicion too. Just never have seen an e30 with driveability issues going through the cluster but I guess it's possible!
                        -NICK
