Broke a bolt...
  • StereoInstaller1
    GAS
    • 22679
    Broke a bolt...
    So today I was installing a different set of control arms, so I could get mine ready for new CAB's.
    Reinstalling, I broke a bolt on the lollipop mount.
    Sheared that bastard about 1/2" in.
    Maybe I shouldn't have used my trusty old Snap-On 1/2" impact gun.
    Anyway, I plan on using Heli-coil to do the repair.
    Anyone ever have to do this repair?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
  • golde30
    • 11464
    did u ruin the threads in the frame?
    IG: @Baye30
    • StereoInstaller1
      GAS
      • 22679
      If by "ruin" you mean totally fucking detroy, then yes, I did.
      I should mention that I fucked up WORSE by attempting to use a easy-out, but I drilled the hole poorly, then didn't notice that I shoved the easy out basically into the threads...then broke it off.
      Destruction...bad uglies.
      Oh well. Gonna order that Heli-Coil tomorrow.
      Luke
      Closing SOON!
      • PiercedE30
        • Apr 2005
        • 4220
        Damn, I pretty much did the same thing.
        I went to my mechanic and he helped me drill it out more, then rethread it with a tap and used a new bolt with some loctite on it. Has lasted a while now without coming out or anything.
        My 2.9L Build!
        • golde30
          • 11464
          this mite be a better solution than a heli-coil...that would only be a temp. fix.
          IG: @Baye30
          • StereoInstaller1
            GAS
            • 22679
            Wow, not too bad an idea. Stock size bolt, or something better?
            Huh? Heli-Coli are tougher than the original threads!
            Luke
            Closing SOON!
            • E30/M30
              • 224
              I snapped a cross member bolt in to the frame, i drilled it out and tapped it for the next size up SS bolt and i now use copper slip on certain bolts to stop them seizing up.
              Helicoils can be good though, they saved my exhaust manifold when i snapped a stud as i wanted to use the normal BMW SS stud.
              Any 335er's out there don't use nut's to space out the studs in place of lost springs on your exhaust manifolds otherwise you will probobly suffer a snapped stud like me. It was only going to be a temp fix but i forgot to replace the springs, doh !
              • BDSax
                Junkyard King
                • Mar 2006
                • 3593
                some douce bag broke a manifold bolt on a lincoln ls i had. i used a heli coil, worked fine.
                NEED SOME VINYL STICKERS???
                • StereoInstaller1
                  GAS
                  • 22679
                  Oh yeah, they were invented in the 30's as an improvement for cast iron threads. Tough as shit, and they spread the load through all the threads instead of just the ends of the thread.
                  Luke
                  Closing SOON!
                  • Axxe
                    • Aug 2004
                    • 3355
                    Reminds of one local guy that broke 2 lollipop bolts and 2 subframe bolts (swapping rack) while borrowing some tools and shop space from me. "Tighten it with the impact 'till she breaks." Easy outs saved the day.
                    Keep it slideways!!
                    • StereoInstaller1
                      GAS
                      • 22679
                      Yeah. I looked at the bolt today. All nasty and rusted, pitted to hell. 4 new bolts and helicoil monday!
                      Gots mah AKG Urethane CAB's ready to install, on my fresh CA's
                      Luke
                      Closing SOON!
