Hi guys. I ordered a digital tachometer to use with on my M42. I know that under normal circumstances I could get a tachometer converter and use a regular aftermarket tachometer, but I wanted something small, square and subtle.
The important details as I understand them are that it accepts a 5v pulse signal. But I'm not exactly sure where to get it. Is it as easy as using the engine speed pinout in the c101?
Here's the item: https://www.amazon.com/DIGITEN-Motor.../dp/B018S87WVU
Here are the electronic details:
Power requirement:DC 8-15V
Measure range : 5-9999RPM.
Clear zero: Automatic
Clear zero time:about 10s.the greater the RPM value,the longer the clear zero time.
Refresh frequency: 0.2-0.5S@120-1200RPM;0.25-0.06S@2400-9999RPM.
Measure indication:RPM<5000,¡À2;RPM>5000,¡À3.
Display:blue 0.56 inch LED
Input sign:Pusle signal,wet contactor signal,PNP or NPN proximity switch,HALL sensor.
Dimension:72x36x20mm,panel cutout Dimension:68x33mm
Operating temperature: 0 to 50¡ãC.
Thanks in advance for any help!
