bad heater control valve?
  • Daeldalus
    • Nov 2012
    • 304
    when you have the heater control valve out of the car and unplugged. Is it supposed to be open or closed?
    I cracked the heater core in my m52 swap car and as i was pulling out the old one I noticed that the heater control valve was not even plugged in. I have been getting great heat and was able to bleed the system(though it took a few tries).
    so I decided to try to blow through the valve to see if it was closed. I was able to blow through it both ways with zero resistance. Is the valve normally open? like does it open when it is unplugged? or is it normally closed, which means I am screwed?
  • reelizmpro
    • 9558
    Edit: seems I had it backwards. It is normally OPEN without voltage and closes when voltage is applied.
    From the ETM:
    When the solenoid is energized, coolant flow is shut off to allow maximum cooling from the a/c system.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • iPee
      • Nov 2013
      • 190
      It is normally open when unplugged, no voltage. When voltage is applied(air temp dial cold) the valve will shut.
      • Daeldalus
        • Nov 2012
        • 304
        OK now I am confused.
        I might just have to put some power to it to check.
        Will that mess up the valve? Putting just straight power to it.
        • Das Delfin
          • Sep 2014
          • 2293
          if you get heat, that means the valve is open. If you can blow through it, that means the valve is open. If both these happen with the valve not plugged in, logic would dictate that the valve is open unless voltage is applied
          • Daeldalus
            • Nov 2012
            • 304
            Well, the people that had this car before me were not the smartest when it came to cars. they had a bunch of stuff screwed up before i got the car. I was thinking that they might have destroyed the rubber diaphragm somehow which would have made the valve open all the time.
            • Daeldalus
              • Nov 2012
              • 304
              Bonus questions
              where is the fuse for the heater valve located?
              what colors are the wires to the valve supposed to be?
              • Daeldalus
                • Nov 2012
                • 304
                definitely never ever test one of these valves while it is out of the car!
                I burnt mine up doing that and had to spend an hour under the dash of nasty car to get another one. and it does work.
                • iPee
                  • Nov 2013
                  • 190
                  If the diaphragm is destroyed it probably won't seal as well. I'm in the process of replacing my heater valve as well, bit the bullet and bought a new one.
                  • reelizmpro
                    • 9558
                    The fuse should be in the same area on the side of the box. It's small and tucked in there so you'll have to look for it.
                    88 M3 - LACHSSILBER
                    • Das Delfin
                      • Sep 2014
                      • 2293
                      check this out
