car wont start
  • E30godz
    • 1524
    car wont start
    alright...after installing the injectors i go into the SMT-6 to set back the fuel...the car starts but is running really rough...it dies, so i assume its rich and dial back the fuel more...i rev the engine a bit and everything seems very light and nice for a second, then i let it come to idle and it dies...
    so i make some more modifications and now the car wont even start..it just cranks away...im not sure if its flooded or not, but it makes no attempt in trying to catch, just cranks a whole bunch. any ideas?
    they are 30lb injectors in for the stock ones..
    also, the last time it started, it wouldnt respond to throttle input at all, it just idled shitty and then died after i floored it a couple times
  • E30godz
    • 1524
    well this sucks.
      • 34844
      Do you have an A/F readout?
      with those huge injectors, you're probably runing waaaaay rich. 30lbs is over twice the stock output!! I dunno.. they just seem like overkill, even on a turbo engine (and you don't have a turbo yet).
      how about resetting the SMT6 to defaults or whatever it was set at when you got it to start, and let the car sit so the fuel can evaporate. I have no idea what to do after that.. you need to somehow cut back the flow of 30lb injectors to 14lb.
      you aren't running with increased fuel pressure are you?
