What methods do you guys recommend to get that damn swiveling end of the thrust arm out of the hub assembly? All the 22mm nuts and bolt are out, and I bought a pickle fork to shove in there and separate, but it wont pop out. Any suggestions?
Not the thrust arm, the actual casting that the tapered end of the ball joint sticks thru, whack it hard with a hammer, it will pop the tapered stud out with a few whacks.
Thanks for all the suggestions guys. BUT, maybe I'm just being a waffleswaffleswaffleswaffleswaffles or something, but I am still stuck with the. I am tempted to put the nuts back on and let a shop deal with the install. Might be hella easier. I've pounded away with my new hammer with no luck. This sucks.
when i changed mine last time, i even try to torch the thing and hammer it. the ball joint was stuck dead there. finally i take my air compressor and power tool works .... :-)
It helps to put some pressure on the balljoint with a prybar while you're whacking the spindle. If you really, really can't do it, then you may be better off taking to a shop. Your likely to cause some damage if it doesn't come out after a couple solid whacks.
