I have a 1990 BMW E30 325i 4 door sedan. The steering wheel is the original. The rubber cover on the steering wheel is loose on the upper section and rotates about the inner ring.
I assume that the bond inside has aged and the outer rubber cover has detached from the wheel's inner ring. If anyone has experience with this and can offer advise on fixes, I would appreciate the information.
I have been thinking about injecting rubber cement or epoxy through the outer rubber cover in the detached areas. The hope is that the bond to the inner ring can be re-established. Any suggestions on this approach would be very helpful.
Any and all comments on this issue are greatly appreciated.
