radio stops when brake pedal pushed...
  • jamiholzbach
    • 311
    I'm having this weird problem. Intermittently, when I step on the brake pedal, my radio cuts out, then comes back on a second or two later. My wipers do the same thing. Has anybody experienced this? where should I start for troubleshooting? I've already replaced the brake light switch and it still does it.
  • jamiholzbach
    • 311
    not sure if this matters...
    the car is an '89 325i coupe
    • MR E30 325is
      • Dec 2008
      • 3300
      I would start by checking connections. Park the car and get it running. mess around with the area near the brake pedal with your hands and see if you can force the problem to occur.
      Run with what you find from there.
      My previous build (currently E30-less)
      http://www.r3vlimited.com/board/showthread.php?t=170390
      A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
      • cheffy30
        • Sep 2016
        • 1159
        look for droppings and the nest above the brake pedal up under the dash
        '90 325i sedan daily driven
        '85 325e coupe also a daily
        • jamiholzbach
          • 311
          thanks for the replies...
          Thanks guys, I swapped the dash out this summer and didn't see any nests or any sign of critter infestation. Possibly a bad ground connection?
          • superj
            • Feb 2006
            • 397
            yup. that would be my guess but just lay on your back under it and start wiggling wires while its idling and the radio is on. you will find it
            • Todd Black 88
              • Oct 2007
              • 3449
              It's your radio telling you to stop being a waffleswaffleswaffleswaffleswaffles and drive faster.
              Originally posted by codyep3
              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
              2001 silver/Blk 325 cabby. SOLD
              2002 325xit Sil/blk. SOLD
              2010 F650gs twin
              • Das Delfin
                • Sep 2014
                • 2293
                sounds like your radio isn't grounded properly.. trace the radio's thick black wire and crimp it to something else
                • TobyB
                  • 5296
                  ....or some Sooper Jeenious pulled radio ground off the brake light lamp circuit-
                  think about it, it'd mostly work until you stepped on the brake pedal.
                  t
