1985 325e coupe, motometer gauges. Just recently bought this car, it's my first E30. Just about worked out all the Kinks but I'm having some problems with my cluster. First, just the speedometer was messed up and everything else seem to function fine. Now the tachometer is idling at about 5k rmps. Like I said, it was functioning fine in the beginning. After I went for a drive and maxed out the RPMs it wants to stay high. When you turn it off the gauge goes down to zero. Then when you start it, it goes right up to about 5k. As far as I can tell they are the stock gauges. I did read about people swapping gauges from four to six cylinders and it giving them problems but I don't think that's my problem. Any guesses?
Gauge cluster woes
1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
I did my own batteries
I read a bunch of threads and watched a couple of videos. Pretty easy but my speedo was jumping then quit. Changed out speed sensor in Differential but think it might be for a later model. Will try a sensor for my 88.
I got my batteries at a local commercial battery store. They even soldered on the leads for me. $8.00.Comment
