Rear battery ground?
  • Simmie
    • Jan 2017
    • 47
    I'm in the middle of converting my '89 320i to a rear battery set-up. However, I think i'm missing the block that is used to ground the battery.
    Here's a picture of my battery tray
    And here's a picture I found on Google of what I think i'm missing
    How do I ground the battery
  • george graves
    • 19995
    I'm surprised there isn't on from the factory - so you'll have to make your own. Grind away paint and then install a lug. Cover with paint of any part that is exposed.
    Originally posted by Matt-B
    • Simmie
      • Jan 2017
      • 47
      Do you think I could make a ground out of the marked area?
      Seems like it would be the easiest way.
      • george graves
        • 19995
        You can make a ground anywhere.
        • jeffnhiscars
          • Jun 2011
          • 6010
          that looks like the fuel filler door. Not the place to run a direct to battery ground
          Alice the Time Capsule
          • george graves
            • 19995
            Sigh. That's not a fuel filler door.
            • e30s50dan
              • Nov 2008
              • 2076
              If you can,just weld a bot to the chassis
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • Simmie
                • Jan 2017
                • 47
                Forgot to update with my success.
                I just ground the paint off using a dremel.
                And found a bolt + washers to stick the ground on.
                Works great
                • george graves
                  • 19995
                  It's a bracket. I would go with actual body metal if it was me. Turn on your HVAC fan, head lights, AC and run your windows up and down. If your lights dim, or that bracket even gets warm, it's a clear sign it's a bad idea. Well, heck - it's a bad idea, but that a test to see how bad it is. No offence - it may work fine - it's just not 100% proper, if you know what I mean.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I'd remove the bumper, drill a hole in the same spot as the factory and put a stainless bolt through from the outside with a nut on the inside. Put a large washer on each side as well and don't forget to remove some paint. Then put the battery cable on with another nut to hold it. Spray over the bolt on the outside with undercoating or bedliner to seal it up.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Either that, or you could use one of these:
                      McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                      • george graves
                        • 19995
                        Rivet nuts are the best! Also called "nut-serts".
                        Not sure I would go with stainless. Then you're just creating a galvanic sandwich.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          I suppose that's true about the stainless. I was just thinking to help fight rust.
                          • george graves
                            • 19995
                            There's more than one type of stainless. All need air(oxygen) to remain "stainless" as I understand them. It's a weird medal for sure. Not what you think it is.
                            • SpartanE30
                              • Jan 2018
                              • 14
                              How much cable did you use to run the power from the engine bay? I plan on doing the same conversion. I have to clean out trunk though first.
