173 ECU and vTPS
  • tbos325
    • Jan 2014
    • 12
    173 ECU and vTPS
    HELLO GUYS I WAS JUST WANDERING IF THE STOCK 173 ECU WILL SUPPORT A VTPS? I WOULD LIKE TO USE the Zt-2 Wide band Air Fuel Ratio and dataloger to help me tune my miller chip.this way i could log both AFR and TP. I realize i would need a adapter to mount tps and switch harness conections. i just was not sure if the vtps would send the same (on and off ) that motronic is looking for
    • 34839
    Nope.
    However, you could use an M30 Automatic TPS - it has both a variable output (originally for the transmission) and the on/off output for the DME, and it bolts to the M20 throttle.
    Also, why are you yelling?
    • tbos325
      • Jan 2014
      • 12
      Thank you, but never mind going megasquirt
