Need help. Alarm.
  • Shane_kent
    • Jun 2017
    • 7
    Need help. Alarm.
    So my 1987 E 30 won’t start the alarm started going off in my garage and now the car won’t start I can unhook the battery to make the alarm go off but when I put it back on the alarm sounds in the car won’t turn over any ideas
  • reelizmpro
    • 9558
    Need a lot more information. Sounds like the alarm has a starter kill relay installed. I'm guessing you don't have the key fob to disarm the alarm. In that case, you want to find the valet switch to disable the system with the key on. If you don't have the remote keyfob, either install a new alarm or remove it. If you remove it, find the starter kill relay, remove it and couple the black/yellow wire back together.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
