Random dash warning lights are staying on
  • 2mAn
    Señior Mod
    • 21061
    I was driving home last night and after hitting a few bumps, the following warning lights stayed on the cluster:
    e-brake
    brake fluid
    battery
    Wanting to make sure a belt did somehow come off I checked and everything looked fine. Drove to work today, they were on, but no issues.
    Same thing just now as I drove to the car wash.
    Any ideas? Is my cluster about to die or did something get knocked loose?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • roguetoaster
    Biggus Tippus
    • 7830
    Check your battery voltage static and charging for a start. Weird, but otherwise unconnected lights being on typically means alternator problems.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Usually means charging system is going out. Although in my case on the m42 my woodruff key on the crankshaft sheered off causing the ignition timing to be way off and i was getting combustion in my headers instead of the chamber. I fixed that and all was well.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • Das Delfin
        • Sep 2014
        • 2293
        My car had this problem when I got it. Changing the blower motor fixed it...
        it's wonky ground somewhere
        • 2mAn
          Señior Mod
          • 21061
          Car died last night, clear alternator symptoms. It died while driving, and when I tried to restart it just clicked conforming my suspicions. However once I got home it fired up immediately. Luckily I’m off work today so I’ll get under it and see if a ground wiggled loose otherwise I’m yanking the alternator and swapping it
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • 2mAn
            Señior Mod
            • 21061
            Hmmmnn....
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Originally posted by 2mAn
              Hmmmnn....
              Likely your issue. And if i was you unless the bearings are shot in the alt just buy a voltage regulator.
              • 2mAn
                Señior Mod
                • 21061
                I bought an alternator from o'reillys. It is a reman'd bosch. Lifetime warranty and the car is back up and running, with no random dash lights on.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • 325e '87
                  • May 2017
                  • 503
                  Hey, was it just the alternator? I’m having the same 3 dash lights come on, but only about half brightness and they go out when I rev the engine. My engine hasn’t died but my headlights and dash lights go dimmer at idle.
                  My son has the 1987 325e, 2 door, 5speed
                  I daily the 1989 325i, 4 door, 5speed
                  • 2mAn
                    Señior Mod
                    • 21061
                    Yup, after the alternator was replaced I was good to go
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • 1984CJ7
                      • Jan 2019
                      • 47
                      hey I'm trying to replace my alternator too but the bottom nut holding it back on is just spinning and there is no space for me to get a tool onto it. any advice?
                      My rigs:
                      1984 Jeep Cj7 (my baby)
                      Lifted 2006 Subaru Baja (the daily)
                      1987 BMW 325e Off-road Build (the new hotness)
                      • 2mAn
                        Señior Mod
                        • 21061
                        pretty sure thats one of those blind ones that you have to feel for it.
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • Sonny
                          • Feb 2019
                          • 100
                          Thanks for posting this! Back on the road
                          Sent from my Pixel 3 XL using Tapatalk
