automatic radiator question
  • blueapplesoda
    • Dec 2005
    • 1904
    i did a 5 spd swap a while ago, and i still have the auto radiator with the atf lines that run through the radiator....
    would i be able to use what was the atf cooler in the radiator and run oil through it? for instance move the engine oil lines that run to the stock oil cooler and put them to the radiator?
  • SpecM
    • Oct 2005
    • 4531
    -I suppose it is possable, but why bother? We already have oil coolers.
    1989 cirrisblau-metallic 325i
    • blueapplesoda
      • Dec 2005
      • 1904
      possibly...turbo.....just wondeing so i could use the stock oil cooler for the turbo...if i decide to turbo....
      • parkerbink
        • Jun 2004
        • 10137
        imho you are better off with less heat in the radiator. Go external.
