E30 door chime
  • AngeloF10
    • Dec 2015
    • 191
    E30 door chime
    My door chime is gonging while off and parked. If I start the car it operates as normal. Any ideas on what is going on here?
    Thanks in advance.
  • efficient
    • Feb 2012
    • 3312
    Maybe the switch on the door is not releasing causing it to stay on. Fiddle with it and see if it stops making noise
    • AngeloF10
      • Dec 2015
      • 191
      E30 door chime
      I’ve tried that. But since it works fine once the car is started, I didn’t think the switch was the issue. It’s driving me insane.
      • cheffy30
        • Sep 2016
        • 1159
        unplug it.
        '90 325i sedan daily driven
        '85 325e coupe also a daily
        • AngeloF10
          • Dec 2015
          • 191
          Originally posted by cheffy30
          unplug it.
          Unplugged. Just wish I knew if it was a problem with the chime? Or something else.
          I’ll buy a new chime and hope it’s not a waste of money.
          • MoreMayhem
            • Feb 2012
            • 650
            I doubt its the chime module itself. If you have a friend with an e30, I'd suggest to try swapping for a moment before buying a new one.
            • ELVA164
              • 4861
              For what it's worth, a new chime is definitely a waste of money. They're hateful devices and should all be exterminated.
              • superj
                • Feb 2006
                • 397
                maybe you could just do that mod to make it play rock n roll
                • jdt10768
                  • Feb 2013
                  • 484
                  grab one from a junk yard and test
