Hey gang,
I’ve searched but haven’t found a sub post specifically regarding a how to or if anyone has used the ECS rocker panel replacement parts.
Has anyone? Can I just buy these new rocker panels, cut out the old, weld in the new. My driver side is rusted but passenger side is fine, nothing visible yet and doesn’t appear too bad but would like it sorted out before it gets worse.
Also, the battery tray in the trunk has a bit of surface rust so I may look at replacing that, ECS has a new one so same thing, cut and weld in? Mine is minor so I may just grind and treat it with some POR-15.
Thank you
Thank you
