Hum vibration
  • Escaport
    • May 2017
    • 62
    Hum vibration
    Well, after about two hours of searching and reading vibration threads I don't feel much closer to an answer of even where to start looking or how.
    My car is a completely stock daily driven 1991 325i convertible automatic. 175k in very good condition. I've owned it since April 2017. There have been no repairs or changes to the driveline or suspension since I've owned it.
    I don't know if it is related, but I had a vibration that started out intermittent. Over about five months I would have one or two instances during a month where i'd have a mild vibration/shake from 0 to about 30 MPH. After about 2-3 miles it would go away. Again, just once or twice a month for a mile or two.
    My current issue. Starting at about 40 MPH, quietly a hum starts to be audible. It's subtle at that speed, but if I'm concentrating I can start to hear it then. I can't feel it in the steering wheel. It's speed dependent. By 70 MPHI can hear it pretty easily with the top up, still to quite to hear with it down. It isn't loud, but it isn't the normal sound I know from previous months driving the car. I'd peg the hum around 500-700hz at 70. The side mirrors blur cars behind me visibly showing the vibration. It is hard to localize and almost feels central in the car. It does not increase or change when turning. (Lets be honest though, I'm not doing much 70 MPH cornering in my stock convertible! :) )
    It isn't like a hard vibration from an unbalanced tire or such. I know what those are like. There isn't any shaking.
    I'm just kind of stumped at what this could be or where to start, and I haven't found anything that really sounds like what I'm talking about in the posts on here.
    Current - 1991 E30 325i Auto Vert, 2013 F30 335i M-sport, 2014 F25 X3 M-sport
    Past - 1986 E30 325es, 1988 E30 M3, 1991 E34 535i 5sp, 1991 E31 850i 6sp, 1992 E36 325i, 1995 E36 M3, 2000 E46 323i, 2009 E60 535i, 2011 E90 335d
  • htseng
    • Sep 2009
    • 158
    Probably a wheel bearing. I have 93 e30 vert with 205k. My hum were the rear bearings but a steering wheel Vibration when cold (oddly better when warmed) despite wheel balancing was resolved with new front hubs.
    • Escaport
      • May 2017
      • 62
      Could be.
      I just tested one thing while driving this morning that may shed more light. I got up to 70 and then put in neutral and coasted for a bit. I'd say about 60% of the vibration went away when it wasn't under power. There is less vibration when I'm not under power, even in drive. Perhaps just a bit better in neutral.
      • jdt10768
        • Feb 2013
        • 484
        driveshaft center support bearing maybe?
        • superj
          • Feb 2006
          • 397
          center support bearing or guibo would be my first looks. we just did rear when bearings on my son's car, which were in terrible shape, and they didn't cause any vibrations. they just roared while driving
          • TobyB
            • 5280
            And if it's not either of those, u- joint in the driveshaft. They can bind intermittently.
            t
            • Escaport
              • May 2017
              • 62
              Thanks guys. I'll give it a shot.
              • MoreMayhem
                • Feb 2012
                • 650
                I had a difficult to find vibration that turned out to be caused by the wrong type of transmission support bracket. It was an aluminum bracket from an e24. Threw off the angles of the driveshaft. Probably not your situation, but a pretty easy thing to check if you’re going to be under the car anyway.
