Steering vibration during turns
  • joonsup
    • 776
    Hi guys. Need some suggestions that I can tackle one by one on why my car has some vibration in the steering wheel as i make a turn at low speeds. This occurs during both left and right turns.
    I doubt it is the wheel bearing since it doesnt make any sort of grinding or humming noises that I heard when my wheel bearing did go out a few years ago.
    I did run over a pothole a few weeks ago with my front passenger wheel so that may have caused some wheel balance weights to fall off but that doesnt explain why i get the same vibration when i turn the other direction.
    My power steering was low a few days ago to the point where there was whining noise so i filled it up yesterday and that didnt fix the vibration issues.
    I'll double check to make sure my wheels are on tight. Any other things I could check for that I may have missed? Any suggestions are greatly appreciated. Thanks
  • tomstin
    • Mar 2015
    • 562
    Jack up each side one at a time. Grab the tire at 12 and 6, give it a shake. Then 9 and 3, shake some more. Any play? Either side?
    You are looking for any loose components. After that, get a wheel alignment, toe changing as a result of the pothole may cause vibration on turns as the wheels are fighting each other. May not show up going straight.
    2004 525i Manual - 1985 325E Coupe Manual
    • TobyB
      • 5234
      While it's jacked up, spin it and watch the surface of the tire for irregularity- you might have broken a
      belt in one.
      And watch the lip of the rim, both on the inside and outside, to make sure it's not bent.
      t
