Replacement starter has different connections
  • irocz0r
    • Jun 2015
    • 41
    Hey guys, I'm replacing my starter here. I have a 4/87 325i. Below, I have the old and new starter pictured.
    The old starter (bottom) had the thick black spade and the red wire attached to the post on the right. The thin black wire was attached to the post on the bottom.
    The new starter (top) has an extra post at the top. Do I hook them up in the same configuration and ignore the extra post?
    OR is this the wrong starter for my car?
  • e30davie
    • Apr 2016
    • 1788
    Do some investigation with a multi meter to see what is connected to what. The extra connection might just be a double up on another connection.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5591
      It looks like its another ground or something.
      • superj
        • Feb 2006
        • 397
        it is the same as the one on your old starter that you didn't take the nut off of. see the brass looking trace connecting the big copper stud to the small stud above it? that is your connection creating the link for the electricity to pass through. your old starter actually had the same trace, but its smaller, and there is no stud/nut.
        just hook your wires up the same way the old one was hooked up
