1211 Motronic CEL bad dme=not so...
  • Mr. Burns
    • Aug 2011
    • 3516
    I've swapped out 3 other known working dme's and I'm still getting a 1211 DME fault CEL light.
    car runs well...ish.
    m30b35 e30 swap.
    in 1990 e30 vert.
    thoughts?
    Sent from my SM-G965W using Tapatalk
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • tomstin
    • Mar 2015
    • 570
    Is everything grounded properly?
    2004 525i Manual - 1985 325E Coupe Manual
    • ForcedFirebird
      • Feb 2007
      • 8300
      Define "well-ish". Drives normal?
      When writing chips and not tallying the checksum, the ECU's do that to me. They will run and drive as the chip dictates, but the CEL stays lit. Seeing you have stock DME's that your are swapping, I am curious as to what would cause an internal ECU fault from something outside of it.
      john@m20guru.com
      Links:
      • Mr. Burns
        • Aug 2011
        • 3516
        I have 2 stock 179's and a Sssquid chipped 179.
        3 ecus' in total.
        the sssquid ecu is 7k rpm, 19# Injectors and 93 octane.
        the light turns in immediately upon ignition and does not reset whatsoever after a battery disconnect for 30 mins or ecu disconnect.
        it runs "okay" as in it doesn't seem happy when you bring the revs up, the idle is hunting at times and overall doesn't seem as responsive as it once was.
        perhaps unrelated, but u blew my turn signal fuse recently which may lead me to believe a faulty ground is at hand...
