Power steering pump tensioner
  • azcoleman
    • Jun 2018
    • 2
    Which nut actually adjust the tension?
    Parts 9 or 10 in http://www.realoem.com/bmw/enUS/show...diagId=32_1826
    Sorry for the mundane post.
  • vpilarrt
    • Jun 2006
    • 2096
    To adjust the tension loosen nut #10, turn nut #9 (that engages the teeth in bracket #6) to the proper tension. While holding nut #9 in position re-tighten nut #10. Cliff notes; #9 adjusts the tension, #10 just holds it all in place.
    • Powling
      • Jan 2015
      • 1291
      Thank you for this - coincidentally I tried tightening my ps pump tension the other night and couldn't figure it out. I'll have to give this a try!
      Steve • Toronto
      1991 318is • Brillantrot
      Build Thread
      • tomstin
        • Mar 2015
        • 570
        For whatever reason, I always seem to struggle getting the power steering belt right.
        2004 525i Manual - 1985 325E Coupe Manual
        • Seawolf
          • Feb 2015
          • 270
          Loosen bolt #5 (the pivot bolt) before trying to tension nut #10, otherwise you'll just strip the teeth off the tensioner #6. Re-tighten the pivot bolt once you have the correct tension set.
          • azcoleman
            • Jun 2018
            • 2
            Good info. Thanks for the help yall.
