Hey everyone, first post! I really need some sane input.
I'm finishing up an LS1 swap on my 1990 convertible, and the Walbro GSS340 fuel pump I installed to feed the engine draws around 9 amps at 60psi. Fuse 11 is 7.5 amps so it won't do. My question is has anyone run into this and how badly did their car catch on fire after putting a 10 amp fuse in its plac? From the fuel pump wiring schematics (if I'm even reading them correctly) the smallest wire thickness in the circuit is 1.5mm, which is around 15AWG and should take 15 amps no problem. Am I nuts, or will it run fine with a ten amp fuse?
This is the schematic I've been looking at: https://www.r3vlimited.com/board/sho...d.php?t=195470
