E39 electrochomatic mirror retrofit
  • PDXPeter
    • Apr 2018
    • 225
    I didn't think this would be complicated but I can't find the wiring diagram anywhere. Ive got a mirror with PN 015313 and it has 5 wires coming out.
    - Blue / Yellow
    - Brown / Black (most likely ground)
    - Red / Black
    - Green / White
    - Gray / Black / with Yellow dots (dashes?)
    Can anyone tell me which wire does what?
  • htseng
    • Sep 2009
    • 158
    Mirror wiring 51160001231
    Pin 8&9 clown nose
    Pin 3 12v switched power. Yellow
    Pin 10 ground brown
    Not sure if this helps. I installed a bmw 5 series homelink mirror in my vert.
    • PDXPeter
      • Apr 2018
      • 225
      Thanks! Do you happen to know the colors of each pin? I dont have the connector, just cut wires.
      • PDXPeter
        • Apr 2018
        • 225
        NM, figured it out.
        Blue / Yellow - Reverse
        Brown / Black - Ground
        Red / Black - Clown Nose LED
        Green / White - 12v
        Gray / Black / Yellow - Clown Nose LED
        • htseng
          • Sep 2009
          • 158
          My connections to check panel. Green white to purple white and brown black to brown
          • PDXPeter
            • Apr 2018
            • 225
            Thank you again! I was looking at those wires as well. Not sure I feel like running all the others up and around just yet.
            • Mike36
              • 1079
              Sweet, I just think about doing this!
