Hello, I was wondering if it is possible that my climate control unit has failed. specifically the cold/heat adjuster. If i remember correctly this part is not mechanic and is electrical..
I came across this thought because my AC is not working. The compressor is engaging and there is the correct amount of refrigerant in the system. I just replaced the blower motor.
Funny thing is that before i installed my new blower motor I swore I felt cold air coming through my vents.
Anyways , AC on , the dial was to the coldest temp and then I turned to the hottest just to check and then when I turned it back to coldest, the air stayed blistering hot.
I am not sure what else it could be and I couldn't find anything about a failing climate control unit. Is there anything else I should check for?
