Broken diff sensor
  • herbie
    • Jan 2011
    • 206
    Broken diff sensor
    Hi guys, So my speedometer was not working so I checked the diff sensor. When I removed it, it was missing one of the ‘fingers’ and I assume the piece fell inside the case. Is it harmful to leave that plastic piece in there? I really don’t feel like paying someone to open the case as I just had a mechanic replace the gasket. Thanks in advance.
    Image 299 C0 B02 BF84 4 CA8 8 B41 8 E9 D8 CD5 ED6 E hosted on ImgBB
  • jeffnhiscars
    • Jun 2011
    • 6011
    My instincts say it's more than a coincidence that this broke shortly after your mechanic replaced the gasket.
    Alice the Time Capsule
    • herbie
      • Jan 2011
      • 206
      I know, but I can’t really point fingers since it was a r3v member plus he offered to check it. The problem is he’s busy and can’t work on my car. I want to get my car painted soon so I was wondering how harmful would it be if I left the broken plastic piece in there, at least until my mechanic gets to check it.
      • Jaxx_
        • Dec 2009
        • 1880
        "harmful" depends on your level of commitment. If the piece is entirely plastic it'll just get chewed up by the gear teeth. If you have an LSD the plastic could embed in the clutches, otherwise I don't really see it doing too much damage. Obviously, it's not ideal.
        I'm sure that if you have been driving it long enough to notice the speedo not working, it probably is already pulp in the diff fluid.
        • D.Martijn
          • Sep 2016
          • 1024
          I mean, it's not that hard to drain the old oil, remove the cover, install a new gasket and fill it up again with oil. There are plenty of DIY articles/videos covering the steps.
          Why not do it yourself so you're 100% the piece that fell into the diff can't damage the teeth, bearings...?
          1990 325iX Touring - November 2018 R3V Car Of The Month
          1980 Volkswagen Golf mk1 1.1
          1974 BMW 2002 Touring
          Instagram
          • herbie
            • Jan 2011
            • 206
            I have only driven the car twice. Once when i picked it up and another after i replaced the sensor. I have LSD, should i get worried?
            • herbie
              • Jan 2011
              • 206
              I was going to, but i could not reach to the top two bolts and i'd hate to lower the diff. My DIY skills are not up there.
              Would getting a set of flex head wrench help, just to get to the top two bolts without lowering the diff?
              thanks,
              • HerbE30
                • Nov 2015
                • 538
                thanks,
                Where I have 12mm risers, everytime I have to work on the diff, I always want to just cut holes in the spare tire well. Just enough for an extension to reach through. I was able to pull the cover off though, it's just annoying and a tight squeeze.
                Could always drop the subframe slightly or try 'offset' wrenches?
                20% Accurate
                Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
                • herbie
                  • Jan 2011
                  • 206
                  Thanks for the response. I'll probably do that, cut holes.
                  thanks,
