DIY on Brake Proportioning Valve?
  • cocofunk
    • Mar 2014
    • 80
    I want to install a Wilwood brake prop valve. Been looking around but cant find a writeup. I am going to keep ABS and try to get this valve on the front driver side fender connected on the rear brake lines. Any writeups or advice? I dont want to do this incorrectly.
    88 e30 with s52 5 lug convo - m3 brakes up fronr and e46 328i rear brakes --> just as an FYI
  • TobyB
    • 5297
    I will start with the observation that,
    if you have ABS, you do not need a valve. ABS
    will fix your rear lockup.
    That said:
    I put a valve down low on the inner rocker panel,
    in the cabin just in front of the driver's seat,
    and rerouted the lines up and back down
    through the floor. 2 new pieces
    of brake line, and it's easy to adjust on the fly.
    Keeping it lower is better for bleeding, too,
    I've found.
    What master are you using?
    t
