Belt squeal when being revved.
  • EbzyyE30
    • Feb 2019
    • 62
    So i have a 89 325i 2 door, i live in Canada bought it out of Nashville. It was said to have a leak everyone thought it was transmission, it was just the power-steering lines. those are getting replaced shortly.
    Anyway, when the car is turned on (parked in my garage for the winter) it sounds good and idles Ok but when i rev it, its an awful super loud screech from the belt.
    My first thought is bad belt, i have a new one but just waiting for some answers. second thought is the power-steering pump is DRY cuz all the fluid has leaked out of the reservoir. third thought bad water pump but I hope its not. Guy who owned it before me took really good care and i think it was replaced 10k before i bought it. (when i drove the car i topped up the fluid and it didn't make it while driving, just revving it was a little angry)
    Thanks to anyone who helps!
  • roguetoaster
    Biggus Tippus
    • 7830
    Well, check belt tension, on the longest run of a belt if you can rotate the belt through about 90 degrees, but not much more you're good.
    Checking fluid is easy enough, and if the pump is a problem just take the PS belt off. The car will still be perfectly driveable without PS.
    • AndrewBird
      The Mad Scientist
      • 11898
      Oily belt from the leaky power steering pump will make it squeal.
      • TobyB
        • 5297
        pig stuck in fan will squeal, too.
        t
        • EbzyyE30
          • Feb 2019
          • 62
          t
          quality:D , ill check for squealing pigs lol
          • roguetoaster
            Biggus Tippus
            • 7830
            You really need to watch it when you close the hood, they like to fly in just then.
