Generator, brake fluid, and park brake lights glowing
  • 325e '87
    • May 2017
    • 503
    When my lights are on and engine at idle and up to 1000rpm, the generator, brake fluid, and park brake lights on the dash glow. They’re not full bright but just glow a bit until I rev the engine past 1200rpm.
    Does this mean my alternator is going out? Or is there a voltage regulator or relay somewhere going bad?
    I guess its obvious that my alternator is weak but I’m looking for confirmation and advice on it so that I can fix the car the way it should be. Any further info y’all have is appreciated.
    The car is an ‘89 325i.
    My son has the 1987 325e, 2 door, 5speed
    I daily the 1989 325i, 4 door, 5speed
  • roguetoaster
    Biggus Tippus
    • 7829
    Brushes are worn, depending on exactly which alternator you have in the car they may be easily replaceable, or you may end up needing a new alternator. Also inspect your alt ground, if one exists, while you are there, and if it looks fishy just replace it.
    • ForcedFirebird
      • Feb 2007
      • 8300
      Stick a multimeter on the battery and see how many volts the alternator is throwing. Generally I see mid-high 13's on an e30 at the battery, 14+ right on the alternator.
      john@m20guru.com
      Links:
      • 325e '87
        • May 2017
        • 503
        Thanks gents. I did the Bentley tests and the voltage was on the low side of spec. The brushes in the alt were approx 7mm.
        I’m throwing a new alt on her this morning. It’s the Oreilly $89 reman unit and will see if things settle. I don’t mind putting new parts on the car, I’m just a little paranoid when its possible that there is a more confusing deeper problem.
        • ForcedFirebird
          • Feb 2007
          • 8300
          Check the brushes before installing. I have had many an alternator that was "rebuilt" where they put the old brushes back in. SMH
          john@m20guru.com
          Links:
          • jbontke
            • Mar 2019
            • 447
            I have seen a bad ground cause lights to dimly glow in other cases. Maybe check the ground and any related connectors for good clean connections.
