I checked and adjusted the ‘off’ function of my throttle switch per bentley. Works exactly as described. Then I went to check the full throttle function. Bentley says open the throttle slowly. When i do that everything checks out - continuity towards the end of the throttle’s travel. However when i took my motor out the stomp test wasnt working. I simulated a stomp by opening the throttle quickly by hand and got uneven results. The ohms dropped but not always enough to trigger the continuity tone.
Has anyone encountered this?
