No fuel no spark
  • Brutal:Engineering
    • Oct 2017
    • 8
    No fuel no spark
    I've got the car cranking.
    The relay under my steering wheel was disconnected.
    Now I have no spark no fuel.
    What's been done.
    New CPS sensor
    Coil pack
    New starter
    All fuse's
    New fuel pump
    Fusable main link has been cut out and is direct to battery at the moment.
    I've got my dash removed.
    Is there any way of being able to tell if my computer is fried?
    Or besides what I have done what would cause no spark no fuel ?
    • Oct 2017
    • 8
    I've tried alot and, I've read through to much.
    I'd really appreciate any help to solve this problem.
    • TobyB
      • 5280
      The relay in the steering column is the turn signal flasher.
      The ecu relay is in the engine compartment. I'd start there
      and here.
      You say coil pack. What engine/car/year do you have?
      Because only the 1991/2 318i/s had a pack, everything else has just one coil.
      t
      ecu's are pretty tuff
