ABS light comes on after hitting a large bump
  • Mike36
    • 1079
    1991 325i
    So the ABS light comes on after hitting a large bump. Turns off of restarting the car and stays off until I hit another large bump. Any ideas? Thanks in advance.
  • jbontke
    • Mar 2019
    • 449
    Check the ABS sensor plugs, most of the time the plastic connector is crumbling. The wires could be making contact with each other or the chassis ground.
    • Mike36
      • 1079
      Do you mean by the one in the engine bay or under the dash. I guess Ill check both.
      • e30davie
        • Apr 2016
        • 1788
        I assume he means the sensor plugs on the wheels them selves. There are wheel speed sensors on each wheel.
        • Mike36
          • 1079
          Oh yeah, I just re-read his reply. I'll check each one this weekend.
          • cheffy30
            • Sep 2016
            • 1159
            stop hitting large bumps.... ?
            sent from hell using Tapatalk
            '90 325i sedan daily driven
            '85 325e coupe also a daily
            • Mike36
              • 1079
              I try, trust me :/
