Found out I had water in the passenger foot well. Found out it was coming from my AC grommet that I hadn’t seated properly from doing my AC. I replaced the grommet and made sure it was installed correctly but it still leaks. I tried silicone but had no luck. With more investigation it looks like there is a leak which drips water onto that grommet when I fill the engine cowl with water. The water comes from the engine hood hinge mount(the upper one). It just drips onto the AC grommet and then leaks into the car. Cannot figure out how to stop either leak. Stopping one would solve my problem. Any ideas?
AC grommet leaking
Tags: None
Water should not have a way to enter your engine compartment. Not exactly sure what "filling the cowl with water" means but do you have the rubber seal this sits on the top lip of the fender and goes around the engine comp ?
Is your elephant trunk plugged and are you sure your AC drains are open ?Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220 -
There’s a thread from 2012 that describes my problem. There’s a crack in the seam sealer inside the cowl where it meets the frame and fender drain. This is allowing water into the engine compartment by the battery. I tried using some seam sealer but I’m not 100% sure where the crack isComment
Are you referring to this AC grommet: 64531372609?
Been there lol. Ended up going to town with some silicone...
Check these out:
GL!"Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked DashboardComment
