So I recently picked up an '87 325is and have been slowly trying to figure out an issue with extreme hesitation / bogging in the middle of the rev range.
After replacing virtually every item that wasn't already new when I got the car, the issue has not gone away.
That is when I realized the "reman AFM" that the PO put on the car is an AFM that has zero cross references to BMW per Bosch's website.
I'm assuming this must have a different voltage curve, etc to the DME versus an actual AFM from an M20. Which I've now ordered, hoping it is the fix I need.
Actual AFM below. Appears to be a Blue Streak reman.
