stuck valve cover gasket
  • robby41
    • Dec 2017
    • 88
    2001 325ci. as said above, any tips i can use on getting it off. i dont want to use a heat gun since the valve cover is plastic. should i just source a new one?
  • KIRIEIW
    • Dec 2012
    • 3385
    Can you not pull it out with a pick? Maybe the last guy glued the gasket into the valve cover cause it shouldn't get stuck, a good yank/tug should get it free.
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • robby41
      • Dec 2017
      • 88
      its the original valve cover gasket, it has 260k on the motor. i've tried with a pick and it only takes off bits and pieces
      • E30SPDFRK
        • 5713
        Heat gun lightly will soften it up enough to get it out without affecting the valve cover.
        Also there is no way you made it 260k on an original m54 valve cover gasket unless you were adding a quart every day.
        Byron
        Leichtbau
        • robby41
          • Dec 2017
          • 88
          neglect from parents, im as surprised as you are. took a hair dryer to it and it came off with struggle
          • jbontke
            • Mar 2019
            • 449
            Why not get the engine hot, put on some gloves, and then try and pull it?
