electric fan and injectors Q...
  • volgapower
    • 161
    i got an idea to remove the fan clutch and install electric fan instead, i think i could gain several HP-s, but is it recomended? and which cars fan should become a donor???
    and question number two... will i get any gain through installing 325i injectors and maybe 3.5 fuel pump on my 318i ???
  • StereoInstaller1
    GAS
    • 22679
    on my 87 325is I run only the AC AUX fan, no cooling issues at all, even in 100 degree weather. I have a switch on the dash.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • DanielHStout
      • Jun 2006
      • 294
      Luke
      How do you wire this luke? Just put a switch in line to the fans main power supply?
      1989 325iX
      1995 540i
      1986 325eS R.I.P.
      1984 325e R.I.P.
      • StereoInstaller1
        GAS
        • 22679
        Nah, easier than that. I used the3 wires that USED to go to the fan switch on the radiator...remember the ghetto-ass wiring that runs over the left fender? (not the wires for the hood pop) And if I had a decent window cut off switch, I would use that as the fan switch.
        Luke
        Closing SOON!
        • gjuu
          • Jan 2005
          • 78
          Luke
          I put an electric fan in my 318is and I am running it off the 91degree switch in the radiator.
          But it very rarely comes on - when the weather gets hot here I have the a/c on which means the aux fan is running continuously - enough to keep everything cool.
          The only time the electric fan comes on is if I am sitting in traffic stationary for 5 minutes or more - I live in the tropics so it can get quite warm here
          • StereoInstaller1
            GAS
            • 22679
            FUCK!...wait, let me rephrase that...FUCK!
            Nice job on the airbox gjuu...excellent.
            [/hijack]
            I cannot iagine any M20 having enough room in front of the motor to fit a fan like that in, but I seem to learn more every day.
            Luke
            Closing SOON!
            • Sean
              • 5793
              [/hijack]
              Luke
              That's an M42, Luke. Thats why he can fit the fan there ;)
              - Sean Hayes
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                so does anyone know how to wire up the a/c aux fan to come on at a certain temp automagically? I deleted my fan clutch and a/c during the m50 swap so i'm planning on using the aux fan as my man fan. thanks
                • gjuu
                  • Jan 2005
                  • 78
                  Yes with the M42 there is a truck load of room - 2 cylinders worth of room
                  Also with no ABS or cruise control - I can fit the air box in the front left corner. And with an IX washer bottle tucked away next to the firewall instead of the normal one, the enginebay looks almost empty....hahaha
                    • 34844
                    it's already wired up that way. all you need to do is change out the temp switch for an E36 M42 and you're set (assuming your aux fan works to begin with).
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      i see thanks, i was always under the impression that it would only work when the A/C was turned on
                      • MrK
                        • Jan 2006
                        • 709
                        325i injectors do not actually put out more fuel than 318i injectors, and upgrading the fuel pump definitely won't make any difference, since it's not a bottleneck.
                        So the short and direct answer to "question number two" is no.:D
                        This is your M20 on steroids:
                        • dude8383
                          • Jan 2005
                          • 10387
                          Sorry to bring this back from the dead....
                          BUT, I have an electric m44 fan, and I'm having trouble wiring this thing up to the radiator switch.
                          • evil_twin
                            • Nov 2007
                            • 2965
                            So I am reviving this thread. If I run an electric fan instead of my clutch fan, is there a way I can have it turn on without running another temp switch? Do we have something that I can just tap into to make it work?
                            Paypal: vdang5@gmail.com
                            Delta Auto Care
                            2875-C Towerview Road
                            Herndon, VA
                            703.435.1375
                            My Feedback Thread: Evil_Twin
                            • ethree
                              • Aug 2007
                              • 1216
                              I have two questions:
                              1: Could I just use the A/C switch in the hvac head to turn on the aux fan when needed? Doesn't the aux fan run anytime the a/c is on and would this work considering I pulled my compressor and lines?
                              2: What kind of setups do people run as far as mounting the fan after seperating it from the condensor?
