Antenna Options? What is this part?
  • doucy2
    • Sep 2006
    • 1311
    Well antenna was missing the gormet so it leaked in my trunk + it didn't work either, so I pulled it out. Now a have a large hole, where the antenna use d to stick out. Has anyone mounted a non-motorized antenna there like an s2000 one (I know rice), or is there some sorta plug I can make or buy to fill the hole.
    Here is a pic of the hole.
    My next question is what is this part?
    And this last pic is an example of what happens when your trunk leaks blah.
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    that holds the car jack in
    • asubimmer
      • 6482
      yeah search for a stubby antenna
      • doucy2
        • Sep 2006
        • 1311
        Haha sweet, too bad I don't have one. Nuts. Thanks.
        • Kruzen
          • Mar 2004
          • 5603
          My antennae is borked as well so I was thinking of fabbing a bodycolor cap with a rubber washer on the underside that would fit flush with the body until I can do a bondo job on it or something.
          Who doesn't love a little BBQ?
          Griot's Garage at a Deep Discount
          • ldsbeaker
            • Aug 2004
            • 3098
            I put a Z3 one in there. Looks good, took about a half hour, and works great!
            Slicktop City!
            • doucy2
              • Sep 2006
              • 1311
              how about this one, think it will work? http://cgi.ebay.com/ebaymotors/BMW-A...43636238QQrdZ1
              • golfdmb18
                • Dec 2005
                • 886
                if you go to home depot/lowes you will be able to find a plug that works fine. The PO on my turbo car bought a plug there and it looks fine.
                • uofom3
                  • Jan 2004
                  • 5392
                  I'd rock the s2k antenna as well if you can find one.
                  PNW Crew
                  90 m3
                  06 m5
                  • doucy2
                    • Sep 2006
                    • 1311
                    yea i can get the s2k antennas for $12 eahs or something like that.
                    • EWAustin
                      • Sep 2006
                      • 234
                      This could work if you had the part that this design is supposed to screw into. ie: a factory non-power antenna.
                      Eric Austin
                      1990 325i Sterling Silver
                      ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
                      • Mastrcruse
                        • Sep 2005
                        • 5340
                        Has anyone used the S2K antenna? I like the e36 verts antenna but I want to put a car cover on so that might not work.
                        • RobertK
                          Kicked cancer's ASS.
                          • Jun 2005
                          • 5864
                          Shave it
                          • Mastrcruse
                            • Sep 2005
                            • 5340
                            if you shave the antenna were would you get signal? Could you get as good of reception?
                            • kenna325is
                              • Sep 2006
                              • 22
                              I bought a cheap antenna that came with a universal mount from Auto Zone. Then I bought a cute stubby antenna that screws on. One problem I ran into when swiching is the power antenna cable end was not the same as the universal end. So you have run a new cable, unless you can figure out how to splice it, but that was no biggie.
