Since the "Big Plans" list is in general, I would like to keep the amount of non-tech posts to a minimum in this thread, which is why I split it up as I did. Here's what I need help with on the tech side of things.
Please respond! (if you think you'll be wasting your time, you're not. I am DAMN serious. I know you tech guys are out there.)
Suspension:
• Please post your suggestions. A 5-lug swap and E36 M3 Steering rack will accompany this.
Brakes:
• Please post your suggestions. A 5-lug swap and E36 M3 Steering rack will accompany this. New brakes may not be needed with E36 M3 rotors, no?
Shoes:
• Proper offset/max width after 5-lug swap is done? Tire size? Fenders will be rolled in both front and rear.
• Hakkapellitas in Winter.
Engine:
• S50B30. What internal mods can be done to this engine to increase its output yet maintain its legality?
Exhaust:
• In the dark here aswell. Stu, what are you running?
Transmission:
• Best selection to accompany the S50B30, as well as best rear diff?
Thank you. You who reply are the ones making this happen. I give you my greatest gratitude.
Kris
Suspension:
Brakes:
Shoes:
Engine:
Exhaust:
Transmission:
Kris
