this is prob a dumb ? but i just started working on my own car. i have an 86 325e and it wants to cut off whenever i push the clutch in at low rpms. for instance if i was in line at a stop sign and i needed to pull up, i can pull up but when i push the cluth in it doesnt want to catch idle. it only does it at low rpmw tho. thanks
help im lost
yeah
for like a week i had to disconnect the battery b/c when i was turning off the car power to my radio, turn signals, and wipers was staying on but i got a new hazard switch and fixed that. but that is about the time all this started happening now that you mention it. so i just have to wait now pretty much?
If you suspect that vacuum leak, then spray carb cleaner around anything that looks like a vac line, i.e. around the throttle body and intake mani and even around the brake booster where the master seats in. (etc etc)
"BMW Style 32 Poster-Child"
HTTP://WWW.CLAVINZERO.COM/e30-5-lug
**(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
ok i just put a new idle control valve on and the car stoped cutting off on me but its still idleing funny. the response in the throttle is alot better but when im just sitting at a stop light it jumps in between like 5 and 7 hunderd rpms. i tried adjusting the valve with the screw but it doesnt help. any ideas.
Originally posted by mbrazier View Postok i just put a new idle control valve on and the car stoped cutting off on me but its still idleing funny. the response in the throttle is alot better but when im just sitting at a stop light it jumps in between like 5 and 7 hunderd rpms. i tried adjusting the valve with the screw but it doesnt help. any ideas.
