Where does the tach get it signal from?
  • nitro325is
    • 495
    Does the tach get the rpm signal from the crank sensor or somewhere else? Think my clutch is slipping at 4500+ when I step on it.Tach Revs rise slower but the engine sounds like it is spinning faster.
  • E30godz
    • 1524
    i thought it got it from the coil?
    • m42technic
      • 1056
      TD signal comes from the crank sensor.
      James Peacock
      WWFSMD?
      • Jordan
        • 12916
        It gets the signal off the pulse sensor connected over spark plug wire #6
        https://mtechniqueabs.com/
        • m42technic
          • 1056
          The inductive pickup on the plug wire is used for cylinder identification only, not for engine speed.
          James Peacock
          WWFSMD?
          • Jordan
            • 12916
            you sure about that? seems to me i have had it disconnected before (not on my car) and the tach didnt work
            • m42technic
              • 1056
              100%
              James Peacock
              WWFSMD?
              • Low Level E30
                • 1646
                I have an aftermarket (read, BIG) tach - wired off of the ignition coil. That's one place where you'll get your speed.
