super high pitched squeel
  • E30godz
    • 1524
    ok, after removing/installing fuel injectors for the 1000th time, i get the car running but i have this super high pitched squeel coming from under the intake manifold/fuel injector area....it seems to be depent on vacuum too as it osciallates in pitch with how much hg/inch im pulling (boost gauge). any ideas?
  • DaN
    • 1265
    Can't think of anything in that area that would make that kind of noise, you sure it's not a belt squealing???
    • E30godz
      • 1524
      found it.
      you know the little "cap" that has a nipple on it that feeds a line to the FPR onthe M20 intake manifold? apprently its leaking.
      • DaN
        • 1265
        "cap" eh?
        Can you get a pic? How can it make a squealing noise? What was it leaking? What does it do?
        • E30godz
          • 1524
          the eta has one too, its on the intake manifold on the valve cover side. There is a bracket that attaches the valve cover and the intake manifold there and has some bolts running through it.
          • DaN
            • 1265
            Oh, the thing that the cold start valve bolts onto, and where the regulated air enters from the ICV, on an eta.
            • E30godz
              • 1524
              yup, on i's though, it just has a nipple for a vacuum hose...apparently air was leaking out the bottle.
