M20 engine build.
  • robbieosterman
    • May 2004
    • 199
    M20 engine build.
  • cahomey
    • Mar 2004
    • 1201
    Your transfer case is gonna be pissed when it hears the news about its impending doom...
    If your going to rebuild your m20 for your IX, I would keep it a mild tune N/A motor.
    Focus on your traction, it's what the IX is "built" for. Forget about your want to decrease it.
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • AdamF 88iS
      • 2051
      You will never get 8500rpm out of that cylinder head. The bottom end will do it, but the head won't make it.
      If you're going turbo, just put a taller rear end in it to stretch the gears out and be done with it.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Sean
        • 5793
        Yea, Adam is right - the head will need lots of money poured into it to get that high - and then you're just winding for no reason. Unless the airflow can go - it'll just suffocate the bottom end.
        - Sean Hayes
        • ptownTSI
          • Jun 2005
          • 1265
          you dont need to turn 8500 rpm's if you have a turbo. you probably wouldnt need to wind it out any higher than stock.
          get a good turbo grind cam, just like you would do with an ohv v8, and run a 3.25LSD you should be golden.
          • AdamF 88iS
            • 2051
            3
            Werd.
            Adam Fogg- '88 M3
              • 34844
              there's no 3.25 diff for the ix, but you can get a set of euro 3.64 diffs.
              • PУCCKAЯ_e30ka
                • Jan 2006
                • 1226
                how about nice head work and itb's?
