Here's the story from friday to bring you guys up to speed.
And below is the follow-up of what my friend and I attemped..some quotes are coming from m42club..
Ok the problem started happening on friday..
I came back home from school and got in my car...ran it for like 2-3 min to let it warm up. This is the usual process when i park my car next to the train station.
Anyways I drive around to find a place to eat...as I'm pulling up to a red light in neutral, my car suddenly idles around 600 rpm. It stays steady at that rpm but sounds like it wants to stall..i checked the wires to make sure none popped out, checked the coil packs and even tried disconnecting the AFM but the same thing was happening.
Where else should i look??
Can it be the AFM? The spark plugs and wires are only like 3 months old...so I'm 100% sure it can't be that.
Oh, and the car runs fine otherwise...just the idle is terrible.
FOLLOW-UP
where are the idle bypass hoses?
I checked the ICV and throttle body...
Will answer the whole thing below..
Didn't blow any money on that, i had a spare..
I tried resetting the ECU..that didn't help
Here's what happened today...
I tried all of the things you guys mentioned.
I switched out the AFM and TPS...that didn't solve anything
This is what my friend and I tried:
Checked the spark plugs and wires...the car was misfiring so we thought that was a possibility..
Removed the AFM and swapped it with one that works...same deal, the car would start and stall almost immediately
We disconnected the AFM and ICV and the car ran BETTER...not great, but much better with both plugged in.
Then we tried plugging them in separately, once with AFM plugged in and ICV disconnected, and then vice versa...same deal.
We're thinking that it MAY be the ECU.. i think that the MarkD chip is sending wayyy too much fuel because the car is running extremely rich at low rpm.
I'm going to try swapping in the stock chip to see if that changes anything.
Otherwise, I'm pretty much out of ideas!
What do you guys think?
FOLLOW-UP
