Help! M42 running poorly or not at all!
  • porsche gt1
    • 237
    I still think it is a fuel delivery issue. Did you check for a fuel leak? how about a plugged filter? Maybe your pump is on it's way out.
    • dirty30
      • 3048
      I had this same thing happen to a freind of mines M42. It seemed to get worse every week. I had had enough so finally I pulled the intake manifold and found a peice of the lower intake manifold gasket had been screwed up on the number one cylinder. This caused un-metered air to be sent into the combustion chamber. The result was the O2 sensor was sensing a lean situation, so it enriched the fuel mixture, which fouled the plugs, caused a misfire, ruined the O2 sensor and finally threw a check engine light. All this was caused by a simple vacuum leak. The situation you are experiencing is the Motronic trying to "hide" the problem.... I would start with the basics before jumping to conclusions on the big stuff.
      • dude8383
        • Jan 2005
        • 10387
        good point...ill look into this tonight!
        • MikesJo
          • Mar 2004
          • 989
          Bad coil pack? I had two bad coil packs and the car was stuttering a bit.
          Vancouver Portrait Photographer
          E30 M3 Wallpapers
          • glucklich21
            • 1912
            Sorry for this bump, but what was the conclusion of the problem?
            Mine was running perfectly the previous day. Then yesterday it started running like OP's when I went to start it for the first time.
            • Matt-B
              The Waffler
              • 3856
              check afm and shit man.
              afm is my worst fucking enemy
              • trackjunkie21
                • Jan 2010
                • 3962
                I'm about 90% sure it's a vacuum related problem. Spray the vacuum lines with some starter fluid, see if the idle jumps. When you start the car when it's cold, does it surge? Does the idle fluctuate a bit? If so, this may be a faulty 02 sensor. BMW 02 sensors are maintenance items, replace them every 10 years or so.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • dude8383
                  • Jan 2005
                  • 10387
                  It was a faulty ECU, replacing it solved the problem!
                  • glucklich21
                    • 1912
                    Well fack.
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      PM sent...
                      Project M42 Turbo
