blower motor & ac dont work
  • jahen
    • 71
    my blower motor has not worked unless its on full blast since i bought it, now the ac button and recirc dont work and the blower motor too. final stage? fuses?
  • Axxe
    • Aug 2004
    • 3355
    I have the same problem, except that the whole HVAC system only works once in a while. I just wired up a switch and 12V to the blower temporarily, looking to fix it for good tho.
    Keep it slideways!!
    • jahen
      • 71
      were are the fuses for the ac and blower.
      • porsche gt1
        • 237
        Blower problem is most likly the resistor pack that controls the speeds of the fan. Replace the AC switch to see if that is that problem.
        • Dave
          E30 RAT
          • 11675
          Another vote for resistor pack. I have had this problem on other cars - fan only worked on high - and each time it was the resistor pack
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • jahen
            • 71
            Sweet I'll Try That Thanks Guys
            • platanos
              • Apr 2008
              • 459
              Can someone please help me? My HVAC system and my window switches or heated seat switches are not getting any power.
              Where is the resistor pack located?
              ~Fernando
              • Uber E30
                • 1409
                http://www.pelicanparts.com/bmw/tech...r_resistor.htm
                Enjoy
                -Alex
                • funcrew
                  • Jun 2007
                  • 1223
                  Originally posted by Uber E30
                  This DIY is for the E36 & you replace the resistor pack from under the dash. Do I understand correctly that to do the E30 resistors, you have to pull the blower motor out of the firewall?
                  "If the sky were to fall tomorrow, the tall would die first."
                  -Dr. Paul Forrester
                  Do I LOOK like I need a psychological evaluation???
                    • 37833
                    The resistor has nothing to do with the problem you're having.
                    If your fan only works on high, it's a very good chance it's the resistor though. Happened to my 89.
                    Grover Beach, California
                    BimmerHeads.com
