removing output shaft
  • NC325iC
    • Mar 2004
    • 6565
    how might i get my tranny output shaft off?
    how do i stop the shaft from spinning?
  • pdx 528e
    • Jun 2006
    • 33
    Use an impact wrench or leave the tranny in the car and use a breaker bar. I am assuming you are attempting to remove the flange for a seal R&R.
    • NC325iC
      • Mar 2004
      • 6565
      trannys out of the car, yes for the seal change as well as making sure i have the correct flange (tranny swap)
      • NC325iC
        • Mar 2004
        • 6565
        i guess ill see if i can get it with our impact wrench
        • Keith M
          • 2338
          I used an impact and a, shoot, I can't remember, 30, 32, 34MM?? socket. I had to used a bench grinder to reduce the outside diameter on the socket to make it fit.
          You'll also need a puller to remove the flange.
          I would install the tranny before tightening the collar nut. (It is torqued/loosened/re-torqued) Have a helper hold fast the engine/tranny at the main engine pulley while this is done. You will also need to use some thread sealant on the shaft itself.
          Keith
          • NC325iC
            • Mar 2004
            • 6565
            its a 30mm socket
