Auto -> Standard conversion
  • Spike
    • Mar 2004
    • 3
    Anyone done it? Is it as hard as i've heard? What all do you need? Do you have to worry about the ecu?
  • Jordan
    • 12916
    Re: Auto -> Standard conversion
    Originally posted by Spike
    Anyone done it?
    Many many people have
    Now that depends on your skill level now doesn't it? I myself wouldn't have any trouble at all with the entire swap, it would be "routine" if anything
    Pilot bearing, flywheel, clutch, throwout bearing, pressure plate, release arm, pivot pin, transmission, slave cylinder, master cylinder, pedal box, shift linkage, shift console, shift lever, leather boot, some minor wiring. These are the major items.
    Realisticly? No. But it is a good idea to get a ECU from a manual car.
    https://mtechniqueabs.com/
    • Bill 84 318i
      • 1600
      What makes you say that?
      • Super Eta
        • 1884
        when and if your looking for a 5 spd let me know i will sell you almost if not everything minus new shaft for 250$ and with shaft for 335. :P
        Just let me know what side East or West of Canada you are and we can go from there if you are interested.
        sorry i just had to do it. :)
        • James Crivellone
          Head Janitor
          • 6305
          ECU's are the same, you just need to do a little wiring to bypass the PARK/NEUTRAL Switch so that you can start the car, that takes a few min..
          • Jordan
            • 12916
            The ECU's are not the same.
            The automatic one should have a lower set idle. Or maybe it is the other way around. Either way, there are some small differences, nothing to stop you from keeping the auto ECU with the 5spd conversion, but just the same...
            • James Crivellone
              Head Janitor
              • 6305
              weird, the auto and manual I's that I have seen idle at 600rpm, i dunno
              • KevinM
                • 51
                There used to be a solid write up at fatdaddybmw.com but the site is down now. Someone said it will be back up again next month. I dunno. Either way, I'm doing it this summer definitely and I'll make some sort of write up with pictures as I go.
                • natorious
                  • 672
                  www.theeurodepot.com sells a kit to do it.. i guess you can call it a kit its all the parts you need for the swap...
                  anyone got a place with a better price as thats definatley the next project on my car
                  • kansas-ix
                    • Jan 2004
                    • 1600
                    yeah my garage has a better price got your ECU, pedals and gertag 260.
                    E30 325ix 62k
                    • christophbmw
                      • Mar 2004
                      • 363
                      hey does anyone have all the parts forthe swap from an 85' 318i. i hate automatic! anyways i am seriously thinking about doing a swap this summer. thanks
                      '91 318is
                      • Garageaholic
                        Freestyle Fabricator
                        • Dec 2005
                        • 5204
                        If they didn't change the ECU number between automatic and manual transmission version cars, then it shouldnt' matter in an automatic to manual swap with respect to the ECU, just keep the same ECU (unless changing over from 1.1 to 1.3 or somethign like that)
                        correct?
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        Instagram.com/garageaholic
                        Youtube.com/garageaholic
                        • Cashdogg
                          • Feb 2006
                          • 67
                          I have two 5 speeds if you make the trip to Niagara Falls....
                          • HST
                            • Jan 2006
                            • 757
                            I really hope he has finished, this is 2 years............
                            Originally posted by KingB
                            Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
